What module for my dodge?
I duno--I am going with injectors first
Mikey....w/o some sorta plug-in somethin'.....you won't get the full benifit of the injectors because of the boost fooler..
I'd say keep your eyes open for a cheap used Edge EZ.....they can be had pretty cheap used, are mostly bullit proof, and when yer ready for something else, it can be resold for what you payed for it...
the EZ doesn't provide much in the way of peak HP, but the drive-ability factor is huge when you let the thing actually fuel a little bit on the bottom end..
--B
--B
x2!
You won't like you truck with just injectors... You'll have the fuel, but no control on the boost. You'll have a ton of power, then you'll hit 23 lbs (where the computer defuels) and your truck will instantly fall on its face...
Try and find an EZ like Berne said... their cheap, work good, and are good for right about 25 horse if i remember right...
OH,
and I've still got those DD2's if you'd like to try them out...
--Berne
Thanks berne but I don't wanna run somebody elses parts---I will buy em first :awesomework:
Anybody know if the only difference between the manual/auto is the turbo--injectors the same?
In any case I just wanna try and do it right...
Auto = hy-35
Stick= hx-35
The hy-35, has a smaller exhaust housing, and spools a bit quicker..
Injectors i believe are the same stock...
