What psi are you guys running your reds
When it comes to reds, just remember that the compound is made to do the work just like a drag slick. Granted tire pressures do make a difference, I think the focus shouldn't be on whether your sidewall wrinkles or not. It's a bit of a pricey chance to take on cutting the thin sidewalls.
Agreed, part of it is the suspension needs a little attention. But thats for another thread. I'll go back up to 7 and 6
If the sidewall bulges sitting on flat ground they are too low. Take them just above that point. If you get a small bulge in a tire when you force it against a rock or ledge while climbing they are just right.
Re: Re: What psi are you guys running your reds
That means I can probly run about 3psi lo
