CrustyJeep
Does this mean you've personally seen cable snap and go flying, to such a degree that Travis' account can be called ridiculous?
I was only stating the of the cables (and rope) breaks I have seen or read about that had adequate details and pictures to believe; that they have fallen straight to the ground.
It's a proven fact that cable stretches when a load is applied at both ends. When something stretches, it becomes a spring or rubber band if you will. If you were to load and stretch the cable to the point of failure, it then has to spring back to its original length. Therefore it cant just merely drop harmlessly to the ground.
I personally have seen a steel cable snap and go flying. I however have not seen a synthetic rope break. Just tossing that out there.
~T.J.
I don't see your reasoning here. The cable should follow a straight line when it snaps and recoils.If the cable is coming out at an angle from the fairlead or has been bent around something (tree, rock, pole, doesn't matter) it's going to have a much greater tendancy to whip out than if it was a straight pull from the winch to an object in front of it.
Snapped right at the fairlead on an offangle pull trying to pull a rig up a steep wall.
And this is rigged right? You think a steel cable needs to be rigged right but not required for rope?
You can make 16000 pounds pretty easy with a snatch block. That should break a fresh piece of 5/16". Try not to stand too close![]()
I read thru half the useless crap before i typed this. Rope breaks and it drops. Simple as that.
I read thru half the useless crap before i typed this. Rope breaks and it drops. Simple as that. No questions. Wire rope hurts people. Eventually.
I have ran rope for a # of years--will never go back...
[Slingblade]Mmmmm hmmmm[/Slingblade]So much nicer to handle, doesn't weight a ton and its easy to work with.
You should buy a toyota then you won't have to worry about your winch problems. Silly jeepers, jeeps are for the post office.:fawkdancesmiley: :stirpot: :stirpot:
Really-----what planet do you live on?
I have seen both break--both have stored energy when they stretch--the only difference is cable has more wieght and there for is more dangerouse.
The question you gotta ask is----if both were to break when you are not ready for it---which one would you like to be close to?
