Scott T.
Rush before the gush
TJ
Dana60/14B
Built 355
350 trans/205case
Real Cage
44"TSL's or 42" Iroks
Dana60/14B
Built 355
350 trans/205case
Real Cage
B Gillespie said:Long term...like after I get out of school and start making some Matt O or Grog money.
Bones said:Ditch the ARB's and go spool IMO
DeleriousII said:one big purchase but can't make up my mind which way I want to go:
Option 1:
Swap 14b for dana 70, 6.17 or 7.17 gears front and rear, detroit for front, chromoly through the front, drive flanges and maybe CTMs
Option 2:
Atlas, chromoly through the front, drive flanges and CTMs
Any particular option seem better than the other to you guys? They should cost within $500 of each other.
InDaShop said:I think you get more bang for your buck with Option #2. If you already have the 14b in the rearend, why would you change it? Deeper gears? Just get an Atlas 6.0 is thats what you're after.....
P said:3.1 Lomax in the 205 ?![]()
Im getting into my pillow block thoughts really hard this AM
Im thinking about ordering one of two different styles and seeing which I can package better to get the absolute MOST out of my 2pc front and get the "angle" were I want them...
This is pretty neat and i think I could manipulate it mounting wise to get the most out of it for my application..
http://www.thebigbearingstore.com/servlet/the-189/1-dsh-3-fdsh-8%22-Two-Bolt-Flange/Detail
This is ol faithful that pretty much errr one is running.
http://www.surpluscenter.com/item.asp?UID=2008110607352135&item=1-207-22-P&catname=
Im going to figure out which one Im going to build to use, then Ill order a couple more to keep around as I know they tend to crack in the housing's from time to time... and in my rig its easy as **** to get to them so Ill be able to keep a good eye on it regardless.![]()
P said:This is ol faithful that pretty much errr one is running.
P said:thebigbearingstore.com actually sells them in SS but they are like 110 bux
InDaShop said:but its still a cast unit though right? Can you cast stainless? The problem isnt the metal type for it, but the casts crack "shatter", vs, the machined will only warp.
