Beerj
Sonzabitches!
Did I miss something? You just using the outers from that mono beam?
Beerj said:Did I miss something? You just using the outers from that mono beam?
FlatlandFSJ said:Yea..you probably missed the high pinion sd60 chunk I got from JJ a while back, it's posted somewhere in the thread.
I'm actually using the entire mono beam minus about 4" of tube. Its why I wanted it so badly, I'm chopping it in half and pressing the ends into the high pinion center as a pass drop front. No setting caster/camber/blah/blah/blah or welding inner C's on, it's easier for me this way with my limited shop.
patooyee said:You'll still need to set caster via clocking the tubes properly.
And AFAIK, Brannik is only doing 1480 shafts. I think the way that he is welding the sleeve onto the 250/350 shafts could easily be adapted to something like an Ouverson stub that was cut to the proper length though.
