Why didn't you leave the bracket and just switch the pedals?
Willy
i questioned the same. i read later why you did it. the "untouched" look. on my yota, i just zip-tied the clutch pedal under the edge of the carpet.hmm.....dont ruin my day.....i didnt realize the brackets were so similar....until you questioned it...i thought that i couldnt take the clutch pedal off cause its on the same rod as the brake....but after closer inspection....i could have done that..DAMMIT!!! OH WELL...ITS DONE NOW...its good when people put you in your place now and then. keeps you on your toes!
nice.I just welded my clutch and brake pedals together to give me the "factory" large brake pedal when I put in my auto. :awesomework:
i always hate doing things PERMANENTLY. i like to give myself an out.
lookin good.Finished the rear shocks and installed the steering box brace with some modification...must have been a different steering box in the xj or frame a tid bit different, anyways...the back of this pile is completely done....onward to the front...needs shocks and front driveline.
i like the build. good job. thats quite a swap, pretty much exactly opposite of what it was before, on everything.
i made some rear, upper shock mounts almost exactly like yours.
not sure if uve had any problems...but,
on mine, i drilled holes, then slid the bolts through, and welded them on front, and the back side. i think it has a bit more support that way.
