CHOP SHOP
Was reading about a guy that used '88 pickup IFS rotors, calipers and Master but didnt say if it was V6 or not. Everything just bolted on his '81 truck tho. I guess the question is, is there a difference between 88 4cyl and V6 calipers and rotors. I know the master is from a V6 cause thats what Marlin sells.
fj80 rotors are solid axle like your truck, but vented and share the same thickness as the ifs rotors/calipers. the ifs rotors are NOT going to workl for you.
You dont need to upgrade the master, yours will work fine. Your brakes just warp to easily so the rotors need upgraded.
Just call me. I got the recipe.
