TBItoy
How much do your springs compress from free length with the jeep sitting on them?
That is how you calculate your sprung weight, and can get a baseline for what rate you need.
As for length, you'll want a 16" lower and 14" upper on a 14" travel shock, regardless of rate.
I wouldn't think you'd want ANY more than a 200 lb lower coil if you are going to use a dual rate stop.
Now Maybe if you had your dual rate stop set really high, and were using it as a "big hit catcher" for the last 1- 2" of travel or so, then a super heavy bottom spring might be desirable. But then you run the risk of hitting block height on your upper spring if it is a lot lighter than the bottom.
I think I'd rather run air bumps for hit control than trying to "spring it" into the coilover.
