jeepmauler
- Joined
- Oct 17, 2006
- Messages
- 2,064
Crash, What do you think of having the fuel pump on all the time vs. run by the ecm? I have sorta similar probs but they were improved by adding a adj fpr.
Also, Mauler. On my sn95(94-95 5.0) there is a larger window on the distributor pickup(hall effect) that orients to #1 cyl. I had some issues with it as the fuel pump triggers at #1(at least it seems with my beater)
Same hall effect set-up in my distributor....we "rebuilt" the distributor twice while in Moab trying to get it to run
I went into jim Greens today to P/U a couple feet of -8 fuel line and ran the scenario by the guys and got anything from too small of fuel line (-8?) too small of pump (the vane pump I have in it is speced for an injeced 460 as well as pretty much ALL Ford injected V-8's) ,to much current draw from the pump causing it to bog(it's not popping the 25amp inline fuse or heating up the wires),plus some others and a bunch of shoulder shrugs.
I may just barrow Brads freshly rebuilt Mallory FI 110 pump(basically a full race pump) and force feed that ****er
