Beerj
Sonzabitches!
I was quoted 275 - 300 to press old out and new in plus welding. He didn't mention about plus material.
Batmobile Will said:I'm not doing mine but why can't you put your tubes in your self with a 2 1/2 is tube as a true stick ?
crawlin85cj said:WOD will retube your axle AND make sure it is straight. It's worth the few extra bucks to get it done right. The downstream effect of an axle that isn't square will kick your ass in parts cost later...ask me how I know.
2012 Jim's Garage YJ
2013 Wide Open Design WFO
Next one is in the oven!
Batmobile Will said:Ok why not just use the whole super duty axle ?
Neal3000 said:Holds up for Dale Larson pretty good
Beerj said:Also, I think someone is working on fitting lower ball joints in the upper location.
Beerj said:Another thing to consider, and this is just something I heard once, is that the extra pinion support bearing on a 14bt was more or less an afterthought. The other 2 pinion bearings are spaced far closer to each other compared to a 60. This allowed too much deflection so they added the 3rd bearing. Again, so I've been told.
I guess the proof is in the pudding if you compare gear failures between axles. And regardless of "why" the 14bt has a nose bearing, it works and is ultimately stronger than a 60.
patooyee said:I doubt it was an after thought. If you believe Steve Gerstner, AAM purchased the designs for the Ford 9" back in the 50's from Ford. They then basically copied it and made everything bigger to make the 14-bolt. There are a bunch of amazing similarities between them when you get down to the engineering level. This is way out of my pay grade but their spline designs are the same / similar, the way the gears are cut are as well. Obviously the third pinion bearing, the threaded carrier bearing collars, removable pinion support, etc. If that is the case its hard to imagine the third bearing being a last-minute addition.
TBItoy said:Refer to the eaton rear end that the 14b is "based" on...
Engineering wise, it looks like an evolutionary step between a ford 9" and a "modern" (70s) 14 bolt.
Neal3000 said:How hard is it to find a Super 60's with the bigger ring gear?
patooyee said:If I was going to mess with that though I would probably just buy Currie 35-spline HP70 gears and be done with it.
Neal3000 said:That sounds like the way to go. HI pinion, 35 spline, add a load bolt= A badass gearset
