BustedKnucklefilms said:Why not Build an 80? Because Bobby Tanner beats on his 14bolts like this with no issues:
BOBBY TANNER BLUE HOLLER BOUNTY HILL BEATDOWN!
An 80 doesnt have that extra pinion bearing. I would build a 14 over an 80 any day of the week.
AJ Rockwell testing an 80- 1000 HORSEPOWER ULTRA BOUNCER BREAKS DANA 80
There is a reason the big name guys are running 14bolts and not 80s. Plowboy is running 14 bolts.
Is Bobby Tanner and Richie running the bronze bushings instead of the nose bearing on their 14 bolts? I know Jake Burkey is not and just grenaded a R&P.
TBItoy said:Did Burkey build a 14b front this year? he has been running a HP60 for years.
BustedKnucklefilms said:Is Bobby Tanner and Richie running the bronze bushings instead of the nose bearing on their 14 bolts? I know Jake Burkey is not and just grenaded a R&P.
tbacon38 said:I just had one come apart in my rear axle so this bronze bushing thing sounds interesting.
Seems like all you'd need is 3 dimensions, ID OD and Length. Pretty simple I'd say.bjeep said:Yeah and there is no tech on it that I have found.![]()
SilverStarCustoms said:This particular drive shaft took plenty of abuse in Moon Rover before being bolted in Warfare with a Steve Scmidt 440 SBC. This is the first time to break.
TBItoy said:Seems like all you'd need is 3 dimensions, ID OD and Length. Pretty simple I'd say.
bjeep said:I will make some no problem. Just wondering why the bearings give up.
Elliott said:Crappy designed bearing, it comes apart and then drops the needles so that they end up in between the gears. I've seen this happen to where it locked up the tires where it got wedged in between the pinion and ring gear.
bjeep said:The newer housings do not use a needle bearing. So is this just for the older housings?
BustedKnucklefilms said:Good Point. What are the difference between the new housings and older 14bolt housings?
Also Jake Does Run a HP 60 front but I though he was talking about the rear end that broke?
patooyee said:I don't know where the one in that video broke but it seems like I have seen several like that break at the weld where the dia. is smaller than a normal drivesaft. Linear weld inches seems like it is somewhat small to be putting it through what some people put them through IMHO. Its why super-high power diesel guys can get away with aluminum driveshafts that are 5" dia. I know space is sometimes a constraint though.
Batmobile Will said:Talking about that if someone has a newer 14 bolt housing before I start I'll buy it off of you , I like the AAM 14 bolts better
