machen4x4
Good job JD hope it works out for ya.
jamie
jamie
machen4x4 said:Good job JD hope it works out for ya.
jamie
Neal3000 said:I wonder which is stronger? 1mm bigger grade 8's or ARP's?
TBItoy said:Probably which ever one you keep tight.
I'd have used 7/16" fine thread socket head cap bolts.
I think you'll be fine tho
Jamie getting all engineery on usmachen4x4 said:The tensile strain on a bolt is much different from that of a stud. a bolt is more likely to break because the entire length must turn to adjust tension.
This creates the risk of shearing the head of the bolt off when increasing or releasing tension. In comparison, only the nut turns on a stud, significantly
reducing the risk of breakage.
let us know how this works for you josh, keep an eye on them bolts and keep them tight.
dragr1 said:With no cone washers it's gonna be nearly impossible to keep those tight. A shame that you can't add more bolts to it and run the cone washers in some of them.
TBItoy said:I doubt he'll have much problem. The cone washers on a Toyota hub are more of a bandaid for undersized hardware, the small studs will break before you can tighten them down enough to do their job, so the cone washer converts some of the shear force into axial force.
With the larger hardware he should be able to tighten it down more.
Josh, what did you torque the bolts to?
dragr1 said:My only concern with tightening it more is that the metal on those wheel hubs is really soft. It won't take much to strip the threads with a much bigger bolt.
TacomaJD said:I tightened em to what felt right lol. I figure it's probably around 40-45 lbs. I will get my torque wrench out and check them one day this week if I can think about it.
TBItoy said:So "pretty dang tight with a 3/8 drive ratchet" (I've found that is in the 40 ft-lb range.
