L
Lone Watie
Guest
I think lamar needs to check the links he provided and then his math. :awesomework:
Dear joshwho?;
OK, I just took the time to check the video:
http://www.youtube.com/user/ExtremeTurboSystems?blend=2&ob=1#p/u/7/UeejadAYKBA
and I must inform you that they were racing to the 1/8 mile, and NOT the 1/4 mile! So yeah, the car busted into the upper 9s in the 1/8 with a top speed of 142 MPH, which is pretty goshdarned slow! In fact, I'd be too embarrassed to show at a strip with something like that. If that Evo were in fact turning turning out 765 ponies, it would would literally LAUNCHED itself from the line like a cannon ball. In fact, it'd be unstoppable. It'd need a chute to slow itself down after a run.
Like I said previously, I was busting out 9s in the 1/8 with an OLD TECH 409 big block. To tell you just how old, GMC stopped building the 409 in 1965! Plus, my 55 Chevy prolly weighed twice or even times what that POS Evo weighs.
Ya see, it's not how fast a car can go, it's how fast it gets there. That's what counts. If a car can't get off of the line, it can't win. I don't care how fast it can go, if it's a dog at the line, it's a loser. I'd trade 20 MPH off of the top end just to gain another 1/10 sec off of my 60' times. That 1/10 of a second gain translates into better than two car lengths at the other end of the strip.
The key to street racing is not about horsepower, it's all about torque. Top end horsepower numbers mean squat when you're street racing. It's all about getting the best torque possible and getting it at the lowest RPMs possible.
Horsepower sells car, whereas torque wins races. This is ALWAYS true in acceleration contests.
In fact, IIRC my last BB Chevy could crank out 672 horsepower, but I didn't even concern myself with that stoopid number, because in truth it's nothing but a stoopid number. It's a number for idiots who don't have the first clue what it takes to build a quick car. notice I wrote QUICK car and not a FAST car. There is a HUGE difference between quick and fast.
No, the horsepower numbers didn't mean diddly squat to me. It was 654 ft. lbs. of torque that caught and held my attention.
And now, let's look at the Mitsubishi Evo from a different light for a second.
The guy claims it is making 675 HP. OK, since we know the weight of a stock Evo is around 3,000 lbs. and we also know the calculated HP of the engine is 675 HP, we can therefore calculate the ride's top 1/8 and 1/4 ETs within about 1/5 of a second either way. The ride should be running:
6.19 in the 1/8 @ 111.6 MPH
9.65 in the 1/4 @ 139.5 MPH
In reality, the car ran a 9.94 ET in the 1/8 at 142 MPH. In the 1/4, it's calculated finish would be in the high 13s. Therefore, don't believe everything that people tell you. I've been racing for a day or two and after a while I can start to spot BS when I see it.
Your friend;
LAMAR
It is rather obvious that someone has never heard of Nelson & Nelson racing engines...
I've seen n/a honda's turn 10 seconds in the 1/4 and boosted/methanol ones pull down towards the 6's. I'd have to say they are definately pushing over 6 psi to do that... :haha:
Not necessarily. The key to this thread is "pump gas". Changing fuel changes everything.
I asked lamar many times what kind of boost would be acceptable for quite a few different kinds of fuel and at what temp the 140psi he stated would ignite pump fuel, but NO responses to the questions that I ask :eeek:
dear lamar:
according to your expansive knowledge and experience there would be no way that F1 engines made 1,000+ hp our of 1.5L four cylinder engines.
but it happened http://www.motoiq.com/magazine_arti...7-cosworth-f1-gba-1200bhp-15l-v-6-engine.aspx
There are MANY variables that can make new things possible and serious questions that you seem to have the answers to, but you won't answer...
Yes there are many variables. The biggest one being fuel used. When was the last time anyone seen a indy car running pump gas? I'm not defending Lamar but why do you feel he's obligated to answer your question about the ignition point of different fuels. The basis of this discussion is "pump gas". The laws of physics won't change because you come up with a new design for anything. If pump gas mixed with the correct ratio of air is compressed past a certain point it will ignite. The only thing you can do to change this is change variables like add water or other chemicals for instance but then it's not just pump gas any more is it? :;
I think you're misunderstanding this. It's not the 140 PSI that's the problem it's the resulting pressure form the charge when it burns. More specifically because it burns before the engine is at TDC. That's the whole benefit to Diesel is the fuel isn't there when being compressed so they can handle much higher compression and boost."A fuel with an Octane RIN of 92 can sustain 140 PSI before it starts to pre-detonate. When pre-detonation occurs, the resulting explosion forces itself past the not fully closed intake valve."
How many people have used a compression tester on an engine? Just a STANDARD, STONE STOCK engine? CRANKING pressure is more than 140PSI
What you list are all variables which will have some effect on when the fuel ignites. The problem is they don't have nearly enough effect to counteract the extreme pressure and resulting temperatutre."At 32 PSI of boost? They would mean absolutely nothing.
You can't alter the laws of physics my friend."
That was his response to me asking "Combustion chamber design, quench, charge temp and chamber turbulance don't have anything to do with how much pressure an air-fuel mixture can endure in an engine before ignition?"
Again don't confuse this conversation with how a diesel works." You can't build an engine that produces enough exhaust gasses in order to spool up a turbo to 32 PSI. Or even 10 PSI, for that matter. To produce 32 PSI of boost from a turbocharger would require an inlet over 10" in diameter with an outlet of less than 1" in diameter."
So are you going to tell the gentalman that chimed in with the diesel making 35PSI that he's being lied to or that he's a liar
What is the static compression ratio of the engines you list and what is the boost?"3.5 PSI in an SBC would be considered as a lot of boost, not overly much, but getting somewhat close to the edge of the engine's limits on 92 octane gasoline."
I hope you weren't being serious when you typed that! :haha: Being stuck in old school ways I'm sure you're familiar with Barney Navarro? Yes, he built a 700bhp 199ci RAMBLER STRAIGHT SIX in 1968 to race at indy! (and I know FOR A FACT that that engine exists) How about Gale Banks? In the 80's he was making a "Stage III 454 that was used for military, commercial and pleasure-craft applications. It produced 540BHP ON 88 OCTANE and 640 ON 91 OCTANE." and he made a turbo kit marketed by "American Turbo Corp." that included EVERYTHING (Nash 5 speed, driveline, exhaust, suspension components, 9 inch rear end, etc) to make a SMALL BLOCK Camaro/Firebird make and handle 500-600HP and if that noe enough he built a 580HP 92 OCTANE SMALL BLOCK THAT FIT UNDER THE HOOD OF THE CORVETTE THAT WENT OVER 200MPH AT BONIVILLE (it's on the cover of the book "TURBOCHARGERS" made by HP Books) NONE OF THOSE RAN UNDER YOUR MAGICAL 10PSI NEEDS A GARBAGE-CAN SIZED TURBO RULE!
Again with the Deiesel thing......"32 pounds of boost pressure will raise your final CR to over 100:1 !!!Yo dipstick! Your cylinder heads won't stay on at that sort of compression ratio! Even supercharged DIESEL engines don't come anywhere CLOSE to a 100:1 compression ratio! Get real please."
FOR THE PEOPLE THAT ARE SAYING THIS DISCUSSION IS STRICTLY ABOUT FUEL QUALITY... LOOK AT THAT :wtf: So again, if you said you're dieselis running 35PSI he says you're wrong and you've lifted a headSpark ignition engines can run well over 50PSI and keep from lifting heads. YOU are the one that needs to get real and do research.
You have been stuck on "RULES" on paper (or in you head) that keep an engine from making power, but those are the only rules I'm talking about breaking, not track rules or anything of that sort. Break the chains and free your mind to learn something that you might not be comfortable with. :awesomework:
I hope you weren't being serious when you typed that! Being stuck in old school ways I'm sure you're familiar with Barney Navarro? Yes, he built a 700bhp 199ci RAMBLER STRAIGHT SIX in 1968 to race at indy! (and I know FOR A FACT that that engine exists) How about Gale Banks? In the 80's he was making a "Stage III 454 that was used for military, commercial and pleasure-craft applications. It produced 540BHP ON 88 OCTANE and 640 ON 91 OCTANE." and he made a turbo kit marketed by "American Turbo Corp." that included EVERYTHING (Nash 5 speed, driveline, exhaust, suspension components, 9 inch rear end, etc) to make a SMALL BLOCK Camaro/Firebird make and handle 500-600HP and if that noe enough he built a 580HP 92 OCTANE SMALL BLOCK THAT FIT UNDER THE HOOD OF THE CORVETTE THAT WENT OVER 200MPH AT BONIVILLE (it's on the cover of the book "TURBOCHARGERS" made by HP Books) NONE OF THOSE RAN UNDER YOUR MAGICAL 10PSI NEEDS A GARBAGE-CAN SIZED TURBO RULE!
I do not know, but I can tell you that NONE of them have a 10" inlet on the turbo and each of them have a larger outlet than 1".
...but even if they did I guess it wouldn't matter beacuse: " You can't build an engine that produces enough exhaust gasses in order to spool up a turbo to 32 PSI. Or even 10 PSI, for that matter."
...and I'm sure there was 10PSI involved in all of those except MAYBE the big block, but he was still putting boost to it with 88 OCTANE!
FOR THE PEOPLE THAT ARE SAYING THIS DISCUSSION IS STRICTLY ABOUT FUEL QUALITY... LOOK AT THAT So again, if you said you're dieselis running 35PSI he says you're wrong and you've lifted a head Spark ignition engines can run well over 50PSI and keep from lifting heads. YOU are the one that needs to get real and do research.
