Kinda new idea...
74_Chevota said:
We have one believer. ;D We are just trying to think a little outside of the box abd working with what we have.
Nothing wrong with that at all, I look forward to seeing how this works out for you. I think if it holds up to the test of time you are going to start a trend for guys with packaging issues or like me, that dont wany hangy down funky bumps on the ass end of thier chassis.
Go jump that sucker a bunch tonight and let us now how it does !! thumb.gif loller.gif
Videos and a bond fire for the test are needed. :popcorn:
It will work fine Sam I am. It will not break like Green Eggs and Ham :flipoff1:
Great job on the pre-fab cleanup, really like the attention to detail!
Matt O bringing the hate! I got tired of waiting for the response to the PM i sent you about borrowing some cash so i could pay someone else to do it. :flipoff1:
I thought you guys were sensitive and understanding...now i see how it is. laughing1
"I got into KOH for one reason: fame and fortune. And now I have a new reason: kicking your ass!" - Happy Gilmore booyang
74_Chevota said:
Hopefully this weekend. Waiting on 2 more bump cans from poly so i can make the other side. Should be intresting...
Hopefully it makes it to the LCQ before blowing out, that way we can laugh at you in person.
:flipoff1:
JK, man I think it will probably work just fine for your Driving Miss Daisy driving style ;D
InDaShop said:
Ok, so I guess my words on the bump needing to hit the pad at or near perpindicular (sp*) (90*) were ignored.
As the bump makes contact with the pad, and is then compressed the snub or (point-of-contact) will have to slide toward the wheel or outward in your application on the pad.
1. that will be very hard to do and not tear anything up on top of wearing the snubber down fairly fast.
2. While that is happening the pressure from the compression of the bump will have leverage on the airshock. In the top picture it will try to rotate it clockwise and up. Therein binding the heim in the airshock.
To try it out: suck the winch down, or figure out a way to suck the front down and do it slow and watch how the airbump compresses and pushes out.
I like the idea, and it will work kind of...... But I think anything hard and the airbump mount rotates up and out, wiping out the airshock heim, and bending/tweaking the whole airshock.
Also the advice that the airbump can not push higher.....the airbump will only push as high into its can as it has limitations. We all agree here. Usually the screwed on nut that the ram extends out of that would be the "Interferance". That will not change. I see the whole bump/can/mount assembly pushing up the body of the airshock as there is nothing "Interferance" above the can mount to stop the assembly from creaping up the shock body. Clamping force aint **** on a suspension. One hard hit and that thing slides right up.
I was a believer then thought about it at lunch studying that photo. I like the out of the box thought, but there are a ton of forces in there you are not accounting for.
Whatever you do, please take pics, and report back.
I understand exactly where you are coming from. You are putting a ton of thought into this and i appriciate it. Honestly, im on the fence right now on if its going to **** my shocks or not or how long it will take. One thing i did do was angle the pads so they hit the bumps correct and not off to one side. Honestly, these shocks are not in the best shape (4 years of abuse have taken there tole) and if they get screwed...well...atleast i tried something different and will most likly step to ORI's in the rear. Part of me cringes thinking about the forces these shocks will take, but something in my screwed up little head says it might work. Maybe college is starting to get to me. pepper.gif
:flipoff1:
I cant help i was born with a va-jay. :'( :flipper:
I agree set up like it is I think it will:
1) Push up
2)Crush,dent or bend the shock body
BUT I do think that this could be made to work!!! What if you take the can that is going over the shock body and lengthen it to the length of the shock body. Then machine a "washer" that is the same size os your new longer can on the outside dia. but only 1/4 bigger than the shaft of the shock. Weld the two together and install from the bottom and now most of the pressure is in line with body and what does try to "twist" or bend will be spread over the entire length of the shock. I'm not sure but I think there may even be four bolts on the bottom cap that you could tie into as well. This should elimate all but the bending or breaking of the bolt which as Chevota pointed out is no differant than an ORI.
I think it will work just fine...but thats just the redneck yota wheelin' side of me that says it will. Lets take it to Mtn City and hot lap it.
I'm betting it will explode, sorry Sam. Not that my vote counts but I had to give it to ya :flipoff1:
On another note, you should be out at Mtn. City flogging the weak links out of that buggy. Perfect east coast testing ground for KOH, just with added water hazards thumb.gif That place was the last time my brother ever road with me, we blew out my old front dshaft on impact, in 4th gear, twice :drinkers:
I think you should just try it and see :flipoff1:
By the way I think I saw you at the game friday? But I wasnt sure it was you and I was hammered. skully
Oh, Mtn City will get the beat down between now and Feb. for sure. Already been out and destroyed my junk (the run that made me swap the motor) so im just hoping the next run wont be as expensive. molaugh Josh, i know your just hatin' cause your rigs not done so i wont hold it against you. ;D
Well come say whats up next time! I dont think anyone at that game was exactly sober. I had a black hat on that said "High Ranger".
