crash2
-Oh no I picked a side-
Oh ya--forward progress...
So after a bunch of work I finally got the crossmember/skid built.
Bolted up to double check final fitment :awesomework:
Since the t-case had a nice mount on the side one thing I fought in my design was trying to incorpurate that into the cross member and still have room for the mount at the frame. This should add a bunch of strength.
So now that the center of the cross member was done it was time to work on the frame side. Marked my locations and then pulled the tranny/t-case back out.
Again I sat there on my back inhailing OLD rusty dust (yuk) and made plates. I ended up counter sinking the plates 1/8" inboard of the edge of the frame rails. I did this for a couple reasons.
The first being the body sits directly on the frame and there is a layer of metal on top/bottom of the frame with rust in etween it and would make for a VERY pourous weld. So I was able to get a good weld between the plate and the main portion of the frame--ok it welded good but doesn't look good (IMO). I also chose to do it in this manner since the tubework is tied into the frame like it is that should minimize any flex to the frame/ causing it to tear apart (like you see).
So I got the tranny back in and started on the crossmember mounts when I ran outa steam.. But I am getting there...
