Maxxis 42" Comp Trepador coming
kushKrawlin said:
Haha. 3" wide! Ha. I did fill mine up to 40. Which is the max PSI. Just to ****ing see what's up, about to measure. The more I think about this the more I want to know how they come up with the tire sizes.
Off the vehicle @ max psi... Bias ply tires are the worse.... 37" pitbulls measure 31" on a 5500 lb rig at 4 psi ... This is another reason reds are so loved, radial tires run true and their carcass doesn't flex as much due to changes in air pressure
My treps measured exactly 40" when I pulled them off the pallet before they were mounted. I don't know why you guys think they should measure 40 when you stick them under your rig.
kmcminn said:
When I pull my cock as hard as I can can it is about 10 inches long. But I don't advertise it as being 10 inches either.
People want what they are being told they are getting.
I almost spit bourbon and coke on my computer. Then I went and measured my Krawlers. 37's measure 36. I thought about measuring my cock...but that was just depressing.
He forgot to add "his cock" is a small rooster named Petie and has been stuffed the last nine years. Let go of the past Kevin, let go
Kel Lawrence
You've been using your fishing ruler again.
http://fishfib.com/
Re: Re: Re: Maxxis 42" Comp Trepador coming
Mortalis5509 said:
Been to hale mountain several times and did a lot on 37's. Even took 40" treps once.
Wow, were you the hardcore trailguide for the Ga Trailriders? Badass......point totally missed
Heard late 2015, possibly early 2016. Anyone else hear similar?
You've got nothing on Jesus, he tied his ass to a tree and walked a mile, not near as stretchy.
Uhhhh ... so what do you advertise it as and where does one advertise such a thing?
I measured my 43 stickies yesterday. Was very depressed at 40.5". That's at 15 psi under my rig though. I considered lifting the rig up and measuring without the weight but that's just too much work.
You guys should measure horizontally not vertically. Just saying the weight is pushing down making the tire shorter. :dunno:
Bahahaha. Holy **** how did I miss that? This fuker here don't even know how funny he is. Classic. One question. Piper I noticed u over here on the white side of the tracks. SomeOne must be Thinkin bout gettin a real tire.. Or have Waayyy to much time .. :flipoff1:
Haha. Hell just do wat Kevin does when he gets bored. Haha
Via Busted Knuckle facespace
Talked to a rep a couple months ago said $800-$1000/tire. I almost started laughing at him. They are a nice tire but need to be competitive with other stickies if they want to sell them. That said when they come out I'll probably have a set :woody:
