B.DRAKE
Damn Josh that chassis is sweet...cant wait to see you
it late in the day after some
caglezxj said:I got ya... Will the power steering brackets and pump you used on your engine fit on my LS2. It is out of a truck if that helps. I will need a good pump so I can control both front and rear. Seems like you found one that would be good for my application. If it will work you got a part #?
B.DRAKE said:Damn Josh that chassis is sweet...cant wait to see youit late in the day after some
caglezxj said:I am sure Jimmy has used this type of radiator before, he already had it for the buggy and this isn't the first one he has built. But I would like to knoiw as well, good question. That is one thing I don't need to worry about is over heating.
EOR MFG said:I used the same radiator on the low low and my old buggy with the 8100 Big block.
I now use larger units, but niether of those vehicles had issues the low low was rear mount and 8100 was a front mount.
I have found that the venting the steam ports, a water restrictor, good shroud, and a vac fill on the system eliminate almost everyones cooling problems. Especially in a rear mount senario.
Matt O. said:You are going to have a blinging ass rig man, I am stoked for you!
