Random Thoughts
Re: Random Thoughts
Zjman said:
Wtf is wrong with people, that sumbitch in Texas killing innocent people and let alone kids, blows my mind, it's a sad time in this country
Constantly seeing this **** in the media all the time and the "fame" these shooters get, just gives more motive to the ticking time bomb crazies out there just needing a reason to act.
Re: Random Thoughts
The price we have pay for living in a free society?
TacomaJD said:
Just received an email invitation from TVA to take the mathematics and qualifications assessment test Nov 9th for the job I put in for, **** yes!
Well did you get the damn job or not?? molaugh
Re: Random Thoughts
Yeah, the adding and minusing stuff is Thursday morning. Gonna be a long ass day being up there early that morning then coming back and working all night. Maybe it will be worth it.
Excerpt from email invitation....
"Thank you for your interest in 505949, Nuclear Material Handler I. As mentioned in the Qualifications listed on the job posting, a requirement for this position is to be proficient in the basic mathematical functions such as add, subtract, multiply, divide whole numbers, percentages, fractions, and averages. You also must be able to convert US weight, capacity, dry measure, length, area, and volume to the metric equivalent. In order to demonstrate your proficiency in these areas, you will be required to pass a math assessment. "
I'm a little concerned about the last part, coverting standard to metric measurements. I wonder what that is going to consist of? I have to do that for haz-mat volume now. If I ship a quart of flammable resin solution via air shipment, I have to label it as 0.95L on the haz-mat docs. But I don't know all the conversions for various volumes and lengths and such. I just know that because we ship that quantity a lot and I use www.onlineconversion.com for any standard to metric conversions I have to make.
In the back of my mind, I think that it has to be a fairly simple test given no college education is required for the job....but I hope I don't sit down to take it and it pulls some wierd **** like "convert 7 inches to centimeters" I don't know many folks that would know how to do that even with college degrees Lol. All we are supposed to get is scratch paper and a pencil, no calculators or external tools. As long as the question supplies some sort of a scale, like "if 1 centimeter equals 0.38 inches, how many centimeters are in 7 inches?", then I can handle that no problem. I always expect things to be more complex than they end up being, just don't want to be caught off-guard. Have to make 80% or better on the test to pass. I've had several 2 year college level math classes that are still fresh on the brain, so I shouldn't have an issue with it.
Re: Random Thoughts
What I do while waiting on the wife to gift shop at Wal-Mart
Re: Random Thoughts
I knew you would come out sooner or later!
I'll have to admit, that's a clever way of doing so.
Re: Random Thoughts
I have to do that every day multiple times a day. After a while it becomes a second nature. Rule of 3 and some basic conversion knowledge and ou should be good.
If you know cm to inches (2.54cm = 1in) you also know all metric measurements to all std measurements.
If you know 1gal = 3.785 liter, you know all std to metric volumes.
Re: Re: Random Thoughts
I didn't know, but now I do. Thanks! haha.
Re: Random Thoughts
If I took that test it would be an all time epic failure....They would frame it and put it up on the wall for all to see and laugh......I suck at math. Factions suck the worst, unless I can relate it to tool sizes I'm lost.
Good luck to you tomorrow.
Re: Random Thoughts
kmcminn said:
decimal mm is .03937 that always help me.
Never thought about 1mm, I deal in making bolt holes, and an M10 is .3937, I've commited very few others to memory but you can always work yourself back out of anything in metric by moving decimals.
I honestly thought 25.4/2.54 was common knowledge (mm/inch is 25.4, cm is 10x a mm)
As for gallon to liter, on the top of the urinal it says 1gal/flush, 3.8L /flush. Always think of a 3.8L engine as equivalent to a gallon, 231cu/in. The urinal helper or engine one should prime you to remember 3.785.
I am going to search on rule of 3
As for volumes, for some reason I'm remembering that 1 cc is a ml. Scales area volume to liquid volume well instead of having to remember a gallon is 231 or a cu/ft is 7.48 gal etc.
Re: Random Thoughts
Me too
Re: Random Thoughts
All these numbers and decimals.......its like porn to me.........aaaaaaaaaahhhhhh LOL
....a'course, most numbers I see are always on the RIGHT side of the decimal. :(
Re: Random Thoughts
You are so FULL OF **** you have to hurt !!!!
Re: Random Thoughts
If I was full of ****...I would'a done'n tried to sell it as manure. Whatever keeps the lights on man. Struggle is real.
Re: Random Thoughts
That why the metric system is so much easier to deal with. it's just x10 or /10 to switch units
or
For ml to cc :
I'm trying to find a table that makes it super easy, just move the decimal on the side 3 times depending which convertion you want.
rule of 3 is :
If you know any conversion ratio (like 1 gal = 3.8 liter), then you can find any gal size in liter and vice-versa.
