Revive Retro
:awesomework: Looking good as usual Crash!!!
on the shock mounts on the spring plates... On all my builds, I generally just touch that inner nut with a tack to keep it on the plate.
sometimes they have a tendency to get loose after some use...
and I use a small enough tack that I can still easily cut it out easily enough if it ever needs to be replaced down the road.
Just a thought...
Just a thought...
Thanks :awesomework:
The pic doesn't show it but I had to grind the nuts in a V shape and are literally wedged into place..
So time to get the last part done so I can paint the inside of the tub.
Bill wanted to retain the CJ fold down tailgate--no problem :awesomework:
So started by removing the CJ inserts for the tailgate hinges---
3 of the 4 hinge bolts had broke off removing the tailgate so instead of making new inserts it was easier to remove the broken bolts.
Mounting the gate was pretty simple. I just measured the Cj from the base of the bed to the center of the hinge holes and duplicated it on the YJ.
There were already 2 holes in the cavity right below where each hinge sits and simply fished the plates up against the body. To hold them I used silicone that would squish when the hinges were tightened.
The last part was the tricky part. I had never made these before and it required some precision to get them right since they hold the cables and the tailgate latches against them. Since they were 1/4" thick the cable bolt didn't have a ton of thread so I milled the bracket down where the cable bolt sits to give it some thread engagement.
Had I done it again I would have tapped the bracket and had the bolt screw into it.
Seems to work as it should.
Now I can prep and paint the inside of the tub,,
So since the gate was done it was time for some prep and paint...
So since I gotta leave the tub alone for the paint to dry--time to jump into other aspects of the jeep--next is the heater box..
Torn apart and cleaned.
New heater core. The whole reason for tearing it apart was to replace it since the tubes where the heater hoses sit were crushed.
I also replaced the foam seals on the defrost/heat door since they were turning to dust,lol.
And of course the blower motor upgrade (73' blazer).. As for the air box its a direct bolt in.
I looked for replacement grommets that go between the box and the firewall and didn't find anything. I happen to go to lowes and found these rubber washers. They are 1/8" thick and 3 seems to be a perfect width.
Now on the CJ tubs you have to enlarge the hole to 3 1/4". Since this is a YJ tub the hole was big enough but only after I removed the metal collar that was around the motor housing(used a pair of flat nosed snap ring pliers to spread it open and off it went). I still had to modify the firewall though for the blower connector.
Time to set the tub onto the chassis....
While I was cleaning the threads for the body mounts I found this. Both sides of the front mount are bent for a frontal impact..
It took some creativity to work them back into place...
