Rockwells make your sac swell!
So you know the years of witch the company changes names and verify shifts within each name, kinda cool history / tech
This was a neapco housing
The cast inner "C"/bell was about .5" smaller than another set of rockwell made housings I had in the shop. The housings were retubed with 1/4" x 3.5" square tube and I had the knuckles lightened up a little. Dropped 40lbs per housing
I just sold my chassis (customer kept bugging me about buying it, so when his offer got up to enough to make it worthwhile, I couldn't pass it up). I am debating whether to reuse the rockwells on the new build, or go with 14bolts and 05/newer superduty inner C's and knuckles since a rockwell shaft will fit in them.
Need to tie those high steer arms to stock knuckle or you will sheer bolts off. Nice arm though
Pretty sure that is the whole point of that arm mirroring over the stock arm, so you can run a bolt all the way through it... :****:
fordcontraption01 said:
Ill see what he wants for a set
Get me a price for two sets. i have enough **** to build as it is so buying something ready to bolt on would be a nice change.
If we can group up and order 4 sets you think he would come down some. If he knows he making them all at one time?
Ill ask and see I do know he has enough material as of now to make two more sets. One of the two sets I got he didn't make the tie rod bolt at the correct angle but those will still work but after I showed him what I wanted he made two more with the correct geometry and got em right then he saved the program what I've got is the first two sets that he has made the shop he works at they make Boeing parts :****:
Id also be interested in two sets also. I'm running front and rear steering and being able to buy arms already made would make life a lil easier. im in if we could get a group together on an order that would be awesome.
Looks like I'm getting a set of mrw wheels for my rocks what is the general opinion on them?
tend to be round, most are black. usually you need 4 of them :****: :flipoff1:
0 Words
