Super Secret coming out of the closet
Got details on the 14b disk setup? I'd rather swap a 14bolt with disks into my 71 Chevy than try to find parts for the drums on the Eaton that's in there.
ya i acn pm you or something some of the details (not real hard, and there's something i would have done differently had i known:booo: )
That'd be cool. No hurry since I'm not doing anything any time soon. I'd be interested in any first-hand experience with certain kits/brackets.
The Pretty Little Dual Cases
here they are in all their glory (note the rad shifter i installed) I had the help of Penetrode Offroad, 84Toyota4x4, and Ashes on this endeavor:haha: that was a fun night:awesomework: nothing like argueing over the wrong things and finding out we're both wrong, backwards and upside down:redneck: :haha:
A shot of the front stuff:awesomework:
And the cute little crossmember:kiss: ( I think it's not going to be enough so i'm probably going to put another crossmember up over the top of the front t-case
And the gratuitous electrical shot:haha: thanks Dad for the help:awesomework: I never would have gotten a garbled up mess if it weren't for you:cool: (actually it's true, it probably would have burned to the ground from grounding/shorting out on me if i tried to "wire" it in, I can "plumb" it in, but Lord knows i can't wire stuff:haha:
You might rethink that tranny mount. I could be wrong but solid mounting the tranny side might play hell on that adapter under torque. How do you have that engine sitting on its mounts?
I like the look though.:awesomework:
Oh no, that's not how it's ACTUALLY going to be mounted, i just got it set up in there until i can get some poly bushings to go between the frame and mount:haha: ya i forgot to mention that:redneck: plus i'm going with a larger bolt sind those are just there to hold it up till i get other stuff finished or get bored and go back to it. I have at least 5 unfinished "projects" i have to do and keep cycling through them because of the A.D.D.:haha:
Back in from the weekend
Well, i got some 2x6" tube and decide to hack out the rockers. I only got one done, but i figure you can get the idea from just one side anyways, i'm having a bit of trouble though as to how i'm going to support the rocker from underneath it i have just two spreaders on it now and plan on 4 more across the bottom, but it seems to be quite a steep angle (not very strong IMO) to attach it to the lower part of the frame to the bottom/middle of the rocker.:mad: but anyways, that'll be for another day now.
sizing it up.
welded on w/ two stringers.
just for reference the stringers are at 5 degrees. travelling up from the frame to the rocker.
spot for the front A-pillar toob thing to start and fender toob thingy to connect into...
it that a fullsize frame with luv body or luv frame?
i wanna do all my **** and have a datsun body/frame and dont know wheather to do a shitload of work to the datsun frame (boxed) and set it up for solid axle or just swap cabs
It's a LUV body residing on a shorten suburban chassis:awesomework: i had a LUV chassis but decide this was going to be easier for me, but I have been running into issues along the way.
sizing it up.
I picked up a stick of 2x6 .120 wall tube to do the same thing. Looks good :beer:
got the other side welded up the same as the first. now it's time to run more stringers and tie it to the rearward part of the frame.:awesomework:
