zukkev
Cornfuzzled yet again...
Speaking of which, the Nuzz hasn't made his presence known on the board in awhile...:corn:
I been thinking that I may do something simillar to this as well. Nuzzy did you do any research on this and how electrolysis may or may not be a factor with the dissimillar metals? If I do it, it would probably be copper on a aluminum radiator....Maybe radiator epoxy rather than JB weld..
Maybee the snow has taken some creature comforts away...
Update: The weizzy have been thru a schedule snafu with nuzz's mom in town so they are busy as all get-up.
I also regret to inform ya'll that nuzzy has very recently sat in his Jeep and made vroom vroom noises.
Fwiw, I haven't touched the jeep mechanically since mid Nov so I still haven't added coolant much less heat cycled the rad. Still curious if my setup will even work.
Thats Great Eric :cheer: Now thanks a lot for stealing all the nice weather and sending the snow our way :fawkdancesmiley: So have you found some local places to play ?
Well, it drove out there under it's own power...
Still have to get a new valve cover 'cause the old one is warped beyond RTV repair. The clutch doesn't seem to be disengaging all the way with full pedal movement even though all the slop has been adjusted out of the pedal (I can still shift but it grinds if rpms aren't matched). I got a coolant leak somewhere around the rad or inlet to the motor after it reached operating temp so I'll have to search that out. But the god damn thing ran![]()
Did you replace the bell-crank with hydraulic slave cyl?
Nope. But all the brackets have been revamped to eliminate any play... Would there still be an advantage to the hydraulic over the manual linkage even considering the play is gone?
Yes and No. I've looked at your pics, and I'd stay with the bell crank.
To get more throw, use a longer rod. But you shouldn't need one. There's no obvious reason that your clutch isn't properly disengaging other than it's worn out (which I don't believe).
If you go with a hydraulic, they've got advantages and disadvantages, which could be a good tech thread
Since those previous pics, I also redid the body side bell crank mount to move it further passenger about 3/4". I lengthened the rod and have it adjusted so that when the pedal sits normally on it's retention spring, the throwout fork has no slop and is meeting resistance. Basically, you can feel the pedal meet resistance immediately upon pressing. It's really weird because it seems like it should be at maximum potential...![]()
Nuzzy
One of your pics (the orbital box installed) shows the clutch bell crank assembly. And it looks like it's about to shear off internally. Take a couple of minutes and unbold that bad boy, dissassemble it, and take a good look at it.
Tony
Better yet, toss that bellcrank POS and do a hydraulic upgrade.
You can use a stock M/C and modify your pedal assembly and drill holes in the firewall for it. Mounting the stock slave is probly just a matter of fabbing a mount. Well worth it.
Lengthened? Perhaps it's too long now? I'm wondering, because the two rods, the upper rod pivots the bell crank, as the bell crank turns, it pushes the lower rod thus moving the clutch. Because you've changed the lower rod to a longer rod, you've effectively changed the ratio of the upper rod's movement. I'm wondering if you're now limiting the throw of that lower rod???
My old 'I told ya so'
Hijack but appropriate:redneck: So Tony, What do you think of the pull type Hyd. cylinders ?
Twas GORGEOUS today
The only local places (within the state) are small parks where guys have trucked in some obstacles. May be worth half a day but can scratch the itch I suppose. However, I've hooked up with a good group of guys that believe in trailering out of state to find gnarly ****Pretty much anything good is 8-12 hours away, but well worth a long weekend. Still debating whether fuel funds will be available to join their planned South Dakota trip this June, but time will tell. :gunz:
nice!
Where you wheeling int SD, I will be in the black hills in june...:redneck:
