Boonie Buster
Stuck on a Curb
Didnt you sell this and buy a miata? :fawkdancesmiley:
Fix your mounts!
He did, he had to sell it to fund his Bead Bracelet shop he is opening.
Fix your mounts!
It'll be THAT much less pucker factor on the side hills of liberty and naches... :stirpot:
Yeah. Thats exactly why I want to pull it off, just to get it lower and more stable. Not to mention if I want to try and drive this thing to its wheeling destinations, I need it to look as small as possible and attract as little attention as possible, haha. Its going to be a project for sure though. Cutting/grinding all those little spacer brackets off the frame under the bed should be fun if/when I get around to actually doing this.My vote is remove the body lift, but that does sound like a lot of work... I personally think there is more to gain from the lowered height that you think. It'll be THAT much less pucker factor on the side hills of liberty and naches... :stirpot:
The hoop is still in the same spot it was in the previous pictures. I just looked and unfortunately I have no updated pictures after it was welded in. The shocks cleared the exhaust though, which I was concerned about earlier. At the axle end of the shocks, I just welded some mounts on the top side of the housing and that was it. Pretty easy really. Next time Im over with the truck if I remember I will try and take some pictures for you of what I ended up with.Can I get some update pics on what you ended up with on your rear shocks? I have the same sky kit I am putting on my 86 4runner and am looking for some ideas with it.
