sleepsontoilet
Can't wait for these to go production. This is the prototype, the actual hoods are going to be carbon fiber I think.
sleepsontoilet said:Can't wait for these to go production. This is the prototype, the actual hoods are going to be carbon fiber I think.
sleepsontoilet;44051858 said:Was routed to this thread, so I'm trying to make sure all I need is a spacer? Engine is a 1999 LS1 from a Corvette that came with the funky flexplate driveshaft contraption. The flexplate, torque converter and transmission all came from the same 2000 Chevy 2500. I ASSumed since it all came from the same truck, it would bolt right up. Unfortunately the flexplate hits the rear main seal cover bolts, and is a long damn way from even touching the torque converter.
gtxracer;44056010 said:I believe you need this spacer:
edit: GM p/n 12563532
https://www.amazon.com/dp/B00E60SLEM/?coliid=I2LV1RGG7T8H9O&colid=1FGPMV84NBXHU&psc=0&ref_=lv_ov_lig_dp_it
Extended bolts:
ARP 244-2902
https://www.amazon.com/dp/B0186VA8VU/?coliid=I5HGXRNPLDACR&colid=1FGPMV84NBXHU&psc=0&ref_=lv_ov_lig_dp_it
edit2: Sounds like you need this flex plate too:
4L80E P/N 19260102
https://www.amazon.com/dp/B00TO611K4/?coliid=I3PVHNNT3TFEX5&colid=1FGPMV84NBXHU&psc=0&ref_=lv_ov_lig_dp_it
I just didn't want to weld the sheetmetal again, and that is what he is having them made from. I'm in no way opposed to fiberglass.ridered3 said:Nice looking hood. What is the advantage of carbon fiber vs fiberglass other than a little bit of weight?
MihlfeldL2005 said:Pro tip here, you can remove the elbow and secure the oil cap right to the valve cover.
Not wasting any space then!sleepsontoilet said:If you look closely, the alt is touching the elbow. Removing the neck wouldn't keep the cap from touching in that same spot without milling the grips off of it.
yeager_0339 said:I used the bomber fab kit on my LS1. It was tight to the valve cover but didn't have any clearance issues. I wish had found the bracket you are using though I bet there is a significant price difference. Looking good though!
Contact KEMP5432 on IGearls69 said:I'd be in for one of them hoods how do I go about ordering one thanks
