Little Gibby's 45 MB
And the wiring is pre-ran to under the dash.
This is where james will have to take over since I have no clue whats instore in the dash but everything is marked with plenty of wire...
With the length I left for the Ecm there should be some good options for its mounting. There is a sweet spot for it on top of the heater box but I don't suggest it going there due to the heat factor.. It needs a spot that will get some air and water resistant....
Made a change this morning and swapped the 3/8 stuff for some 1/2. The 3/8 was a little restrictive.
The front/rear harness is done. I pre-wired Park lamps/brake lamps/LH&RH turn lamps. I also pre-wired for a fuel sender in case dale wants to add one to the tank down the road and also a turn on wire for the air pump.
Got the main junction pass thru installed and all the main power feeds from there forward done (alt, starter and winch). That finishes the wiring I will be doing.
whats the status of the shocks dale?
I can't remember if stated some time ago but its also missing the dipstick tube.
I have 2 weeks and it has to be done as I have to get my gold bar house ready to go on the market and another big project to start.
Wait, soooooo you're saying this thread will officially end in two weeks.....after HOW many years??? :fawkdancesmiley: :haha: :hello:
James is going to have to keep it going for a bit with his finishing touches.
SM465 shifter parts are on the way to you Mike.
The water neck and distributor hold down are ordered but they had to ship to me, then I will forward them to you.
Shocks and hoses should be on your doorstep on Thursday.
