Re: S10 build sas aka rasta truck
Go to DIY4x.com or Barnes and buy some tabs, it will save a LOT of time, and help keep your rig from looking like a hacked together piece of crap
If you're running 1.25" od for links they will taco before you release the clutch. Especially at that length. 2" x .25" minimum
1.25" x .25" I know two or three guys who have it done with this and have no problem with it bending
Re: Re: Re: S10 build sas aka rasta truck
Best of luck to you sir.
Me tie-rod was made of that size, which looks to be shorter than your links and I put a good bow in it.
onetoncrawler said:
molaugh molaugh molaugh molaugh
Yeah man, good luck with that...
Why am I nervous? I'm going to stop calling ours a budget build.......L
Just a suggestion (it's your build, do it like you want it) get those link mounts off the bottom of the axle. They are gonna be boat anchors when you get on the rocks. Your lower links are extremely long. The longer the link, the more likely it is to bend.
How long are you guys runnin your links
Mine are 36" bolt to bolt. They should be no longer than 40" in my opinion.
Ours are 38 eye to eye. Do some shopping they sell the link brackets very reasonable these days,
The thickest pipe my local metal store sells in 2 3/8 is something called sch 40? How thick is this?
http://www.ebay.com/itm/200973070473
This is what you need
"Pipe" is not what you want. You need TUBE. There is a difference. For links you want DOM tube. Because I'm on a tight budget I did use 2"x.250 wall square tube on my front links but I also made sure to use good inserts and joints. I am also a crawler and not a bouncer. I daily drive my rig.
Got some 22" coil springs for the front of the sten I'll have to lift the back up more to even things out I'm thinkin about the dual leaf springs on each side for the back any one have tips for that?
Dual leaf springs are great for lift on a budget. Go for it and be sure to post some pics! I can always use ideas.
