Re: S10 build sas aka rasta truck
Hey just getting motivated to drive to shop and work on it today
Still have to make some brackets where the springs go to the axel will get more pics up tomoroww
I'm by far anything close to being smart on link geometry. But I'm assuming you changed from 4 link to y link or 3 link ? Being that your lower are strait? If so what you thinking on a trac bar design? And where you gonna be wheeling this S dime at? Fer the first shake down :popcorn:
Still not sure what I'm doing for the others links still some tweaking in the future probably be hittin smorr for the first ride it's about 45 min from the house
Sit at 37 inches in the front and only 27 in the back back has to come up after I get the front done
The 2" square tube seems to be a lot better thanks for the advice everyone
I have no idea yet any suggestions
Is there a thing as too high because I think my front end might be in the bracket
It looks high now, but just remember it will settle quite a bit when you add the weight of the drivetrain and front clip. The pinion angle may be a little off, but hey, it's a wheeling rig, right? :driving:
Yeah I still have to set the pinion angle when I do my other links too
Where the springs hit the axle should I tie those up some how where they don't seperate or just leave it where it can drop lower than the spring and when the axle comes back up it meets the springs
Re: Re: Re: S10 build sas aka rasta truck
Spring perch. Or bucket.
Jeeps let em float. Doesn't work that great, but it works... Kinda.
Check out other builds and what works for them
Feels like there's goin to be a lot of shot cramped up on my front end I have to figure out where I'm goin to run the shocks my other links and my steering situation not counting brake lines too suggestions are appreciated
In the future if you need to make it lower you can always build some spring buckets that come up beside the frame but agree that once motor and etc is in it will settle quite a bit.
I'm think everything in it will set it down atleast 4 in
I think I just figured out the name of the truck thanks
