6.0 Horsepower upgrades?
So anybody with good reports on the larger ported/polished tb's? Stock is 75mm. I know the fast stuff helps, but I don't have the money for it. Just trying to decide between a stock tb or a 80mm unit?
my ls motor is pretty strong and im on a stock mass air and throttle body. i could see better ways to spend that 1500 to 2000 for the fast setup
I didn't buy a throttle body for increase in power. I needed a 4 bolt pattern cable throttle body for the L92 intake. Stock on my LQ4 was 3 bolt pattern.
Going with an LQ4 6.0. Ended up with a free car intake and gave $100 for a ported stock car TB & rails injectors. Found a GMPP Hot Cam with springs & retainers for $200 and couldn't pass it up. Should be a pretty good little cam:
http://paceperformance.com/index.asp?PageAction=VIEWPROD&ProdID=242853
Only parts I still need are flow through fuel rails, headers and the gated pan. EOR does the ECM tuning in house and we are going with a brand new custom made wiring harness.
just for your info....
LS1 Camshaft Specifications
1998 - 2000 Fbody
202/210 int/exh @ 0.05" duration
0.496" / 0.496" int/exh lift
116 LSA
2001 - 2002 Fbody
197/207 int/exh @ 0.05" duration
0.467" / 0.479" int/exh lift
116 LSA
2001 LS6 cam
207/217 int/exh @ 0.05" duration
0.525" / 0.525" int/exh lift
116 LSA
2002+ LS6 cam
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
GMPP Hot Cam
218/227 int/exh @ 0.05" duration
112 LSA
GMPP ASA Cam
226/236 int/exh @ 0.05" duration
110 LSA
6.0 LQ9
207/196 int/exh @ 0.05" duration
0.479" / 0.467" int/exh lift
116 LSA
5.3 LM7
190/191 int/exh @ 0.05" duration
0.466" / 0.457" int/exh lift
114 LSA
LQ4
99-00 12560967 191/190 .457/.466 114
01-04 12561721 196/207 .467/.479 116
01-04 LQ4 cam is same as Camaro, Corvette LS1 and LQ9 cam
I have the 02+ LS6 cam in my 5.3, the power is good....but more would be better! :driving: :woot:
Matt, sounds like you have a good plan for your motor. keep it simple and reliable. It seems like you are trying to address the problems that alot of people are having with those motors when racing...... :dblthumb:
Brian
Brian I really have no idea what all the numbers mean in relation to the aggressiveness of the came but I was told the GMPP is similar to the LS6 cam and that is what I was looking for. Something better than stock but not crazy. Reliability is important to me
COPPERHEAD42 said:
how much lift can the stock l92 springs take ?
I think it is generally believed that they are not good for anything above stock. Aftermarket springs are considered mandatory with virtually all aftermarket cams and I have never heard of anyone NOT doing it.
J. J.
alright. I was the high bidder on a l92's last night but got out bid at the last minute, they sold for 720
You probably didn't want them anyway then. I think I just paid $640 shipped for mine, they are new with rockers, valves, and springs.
J. J.
J. J.
Did you receive them yet? I'm looking for mine any day now.
COPPERHEAD42 said:
Ya ill keep looking. If anyone see's any I would appreciate a heads up
thanks
Just pay attention to that thread I linked to in a previous post above. You can sign up with ls1tech.com and then subscribe to that thread to receive emails instantly when it is updated. He gets those heads in often and they go quick but they're the best deal on L92's I've seen.
J. J.
Haven't posted anything in a long time. I had some major motor issues with the truck on New Year's. Chris at Danzio Performance built me a fire breathing 442 LSX block motor with a Callies Forged crank, 4.125", H-beam rods, custom JE pistons that Chris designed. Chris also designed his own custom solid roller Cam. He used T&D rocker arms, ported my L92 heads, and did a whole lot to more to build this motor. He dyno-tuned the motor, and it put out 732 hp. to the crank at 6200 rpms. The motor revs all the way up to 7300 and still making good power.
How about that
kid rok said:
How about that
Amazing, huh? That si an aftermarket block though. The LSX is a GM Performance Parts iron-block containing the best of all the LS block features. It can be made up to 500CID and support over 1500 hp. All that in a small-block package and weight. So he's definitely got some money into that motor.
J. J.
Travis said:
Mine will be here today, according to Fed Ex.
Yup, mine just got here shinny and new! Like I said though, they're not going on for quite a while.
J. J.
