All engines gas or diesel with the in line ciylinder design. Have proven them selfs in torque power and long lasting lifes. 4.0l jeep 300 ford 225 slant six dodge and 5.9/6.7L cummins. And thats where Dodge pulls ahead.
I work on them all so it makes no difference to me. But for the sake of this thread. I see more Ford/ Powerstrokes in for repair than I do Dodge/ Cummins trucks.
If I did get a ford I would get the cool BBQ model one.
[YT]http://www.youtube.com/watch?v=v36MCcRPRTc[/YT]
Jaydog.. Come on over and we can ditch that crap.. I just did it to my friends mega cab. Not a bad job at all. I can get the Smarty, exhaust is CHEAP. Then you just need to pick up some H&S block off plates. :awesomework:
X2. Do it Jay, it's WAY better that way!
What in your opinion are the weaknesses of these engines?
We were 1 repair away from getting a '05 F450 Lemoned, Almost had to take Ford to court![]()
So you think the Cummins is better just because the inline 6 is a better design? Based on the fact that there has been other 6's with a good record?.....The same could be said about the V8 design too.
The inline 6 IS a better design for diesel engines than a similar displacement V8 engine. This is because an inline 6's longer stroke takes better advantage of how diesel engines operate relating to their high compression.So you think the Cummins is better just because the inline 6 is a better design? Based on the fact that there has been other 6's with a good record?.....The same could be said about the V8 design too.
Jaws tows with a ford truck and is endorsing the cummins.
Ha rick?:haha:
There's nothing that says a inline 6 engine must have a longer stroke. Lets hear some actual numbers....The inline 6 IS a better design for diesel engines than a similar displacement V8 engine. This is because an inline 6's longer stroke takes better advantage of how diesel engines operate relating to their high compression.
I'm not saying one is a better design than the other but don't assume because one is used more therefore it must be better. In my OPINION 6's are used more because they're much cheaper to make.Why do you think the majority of medium and heavy duty over-the-road trucks have inline 6 diesels instead of V8 diesels? It's been done this way for decades and V8 diesels have been tried and discarded as a viable alternative to inline 6 engines .
I read a story on a forum some time ago about two 18-wheelers leaving their yard with the same load and had the same destination. Both were very similar except one had an inline 6 and the other had a V8. The V8 equipped truck pulled ahead of the other truck in the beginning on the flat stretches of the Interstate, but once they hit the hills, the other truck caught up and pulled away.
Whatever you guys want...I'll be the first to say the 6.0s had issues and I would not buy one.
Ford 6.0 V8 diesel--95.8mm bore, 104.9mm stroke = 0.91 ratio.There's nothing that says a inline 6 engine must have a longer stroke. Lets hear some actual numbers....
Binder, I don't know what you are after here. But I don't see why you are trying to fight it so much. People don't buy Dodge's with the cummins in them, or swap a cummins into their Ford, just because it's the cool thing to do. Go out to the powershop, or DDP, any of the diesel shops in our area. Ask them which one keeps the lights on in the shop.
Jaydog.. I'll see what kind of info I can dig up on the C&C.
Cummins 5.9 I6 diesel--102.1mm bore, 119.9 mm stroke = 0.85 ratio.
