Today was a bit more productive. Got a little bit of an earlier start, but I still didnt get up until 2 PM. I have to work at 5 PM tomorrow, so Im trying not to break my sleep habit TOO much...
Anyway, I went to work on the front hangers first since I had finished up the rear shackle hangers already. I got those welded on. I also cut off the old hangers with the torch real fast. Still need to get in there to clean them up.
Drivers side
Passenger side
...And shot them with some paint
After that I got the springs hung again, and got the axle in place under it
Got that all bolted down and everything tightened (had to go buy new tools since my set stopped at 26mm, haha), and tried to bolt up the driveshaft. Im gonna need a new one after all :frown:
I had hoped since the old shaft was made with a 4" lift already on the truck that I would be able to reuse it. Turns out its a few inches too short. I was able to take a look at the pinion angles without moving the spring perches though. It doesnt look TOO bad...
And heres why I need a new driveshaft
So, I tossed the rear wheels on it and (carefully!) pulled it out of the barn.
Heres Ashley excited and hugging the truck, haha.
Here are a few random shots showing shackle angles and such.
Anyway, I can already tell its gonna be SO much better than what I had, as soon as I get the driveshaft fixed. First bump I hit moving it around the driveway, this happened, haha.
I also started messing around with the front. I got the drivers side shock tower cut off and ground smooth before it got too late to work again. I plan to get the other one cut off next weekend, and tear into the front. I will also be fixing a few other things up front that need attention, and installing some 30 spline axles from Bobby after I pick them up (hopefully Monday):cheer:
~T.J.
