Got back to work on it, and Ive decided I may have messed up the spring hanger. Im not gonna fix it though, Im just gonna live with it. Trail Gear doesnt specify which direction to mount it (the spring bolt holes arent centered with the square tube), so I went with Marlins directions to put the longer side forward (1/4" offset), but they said to mount the hanger flush with the front. I also went with Trail Gears directions to mount it 3/4" forward from stock. This makes the spring bolt holes roughly one whole inch forward from stock. My rear shackle angle at ride height is basically verticle. Im HOPING that once they break in a little, I will get a little better of an angle out of it, but Im not holding my breath. I should have triple checked it before I welded the hanger in place...
Anyway, heres a picture of the front welded up and painted (I forgot to take pictures of the welds and such)
And the (bad) shackle angle at ride height with the weight on it. It actually isnt "negative" like the picture looks. It was actually vertical. It settled some to a LITTLE less that vertical after I bounced it a bunch and flexed it a little.
I started playing around with the engine hoist and flexed it out a little. It actually looks like it will move pretty well. The rear left tire is about 20" off the ground, and the rear springs are hardly flexing at all. The shackle on the front right is about 1/4" from hitting the body mount, and the spring is flat. Looks like thats where I'll be making bump stops. Front left isnt at full droop yet either.
Anyway, this is the furthest my truck has EVER flexed, and its not even that impressive, haha
I also got bored and decided to attempt my home made driveline idea. I cut the end off my rear shaft which was too short, cut up a 1990 front shaft for the CV joint, and mated the two to get the length I needed.
Tomorrow I will be welding it up, but the CV fit into the rear shaft tube PERFECTLY (with some help from a 5 LB sledge), and I got it phased and aligned "square" with a machinist square. So long as it doesnt have a TON of vibrations, I will be happy. Im at about 55" compressed, and it will ride at 56.25", with the rest of the spline shaft for extension. I didnt take any pictures, but I will tomorrow when I work on that some more. The new long spline kit is on the way for the front, and I got some good practice taking drivelines apart tonight so Im ready, haha.
At this point I still have to do front and rear shocks, shock hoops, gussetts for the spring hanger, driveline work front and rear, and some brakelines.
So, thats all for tonight. A sucessful night all in all. I told you it would be back on the front axle today
~T.J.
