The new and improved Sausage
Please speak more on this subject :eeek:
Just a guess but I would say it builds pressure quicker and easier that way so even with 49 at a super low RPM you can still have fulll grunt on the steering??????????
IDK just a guess I just guess something haveing to do with moving more volume quicker and easier:awesomework:
Thats mass fawking cool!!!! Wow thats some thinking right there!!
So is he running just a single large resiovior or two individual ones??????
single gallon reservior.. or close to it
I cant wait to beat on it myself :redneck:
Paybacks sucka
one for front and one for rear :;
Wrong:eeek:
The tc pump puts out more pressure than the P pump. It also puts up better with high RPM. The tc pump is great far as pressure, but lacks volume.
So, two tc pumps plumbed parrell give me pressure and volume, and the ability to run at high RPM. There are check valves in line with each pump incase one dies I can still drive.
So.. with two pumps, a one gallon resevior, a cooler with fan, I should be ok.......high pressure and good volume
Hydrogen= no sparks required. Maybe he's far enough away for the gas to not be a problem but I wouldn't do it.:FIREdevil:
Puss.....I'd weld ON the batt.....fug it!:flipoff: J/K ****...you wheelin this weekend?
Wow so I actually had the general Idea down????:cheer: more volume and pressure except i thought for low rpms but high makes more sense:;
A friend and I were jumpstarting a car, when the battery blew up in his face, it was as loud as a shotgun, and he got hit in the eye with a piece of plastic, and had acid burns on his face. His eye turned white and he was blind for two months, he is fully recovered now (this was about 8 years ago). I have never had an accident from welding or using a torch, even when scrapping gas tanks. Optimas are gel cell batterys and do not have open space inside to collect Hydrogen gas- which causes explosions.
