And damn---my pic server just went down![]()
Right before I go to sleep....you cruel, been waiting all day for the pics.
I love it... so clean.
Shutoff valves for the breathers... this buggy screams "Roll me!".
Why not something automatic for the breathers, instead of having to manually turn the valves?
http://www.speedwaymotors.com/p/451,58_Tip-Valve-For-Tank-Vent.html
Those only work when youre "perfectly" upside down or the valve itself is vertical.....and rarley are you "perfectly" upside down for the ball to seal.
Have you given any thought to some kind of shield around the orbital valve in case of a leak? A high PSI hydraulic fluid leak could be deadly.
that thing is gonna be heavy:;
any guess on final weight?
Has your buggy ever been on a scale?
In the orange buggy I had I accidently locked the front and rear in hi and low at the same time and the rig was under such a bind that I thought it was going to send parts flying(didnt even want to move). When I did this it was in the dirt, somebody left the pills out when the T-case was built and it was a complete bitch to get it back in normal range. If you attempt this with the gearing/tire size, and your inability to know when to say when something will surely go "BOOM"very quickly. Been there done that, wont even accidently do it again as there is a reason they put the pills in it. Also Mike how close is the queer steer joystick to his leg? Robin likes to haul ass and I would hate to see him hit it with his leg at high speed. Other than that looking good, nice work Mike.i'm thinking of the options.....a front burn in highrange and a rear burn in low at the same time
front in high rear in low while climbing wet rock
