I read this too late----I won't be able to get this off till tonight
Ok here are the loads on the rig...
Taurus fan
On start:95 amps
Running:35 amp
Both p/s cooler fans
On start:26.6 amps
Running:10.8 amps
Trans cooler fan
On start:15 amps
Running:6.1 amps
Headlamps
On start:13.8 amps
Running:8.7 amps
52 amps for cooling. 61 amps with lights. That's a bunch.
Any idea how many amps that alternator puts out at trail-type RPMs.
What kind of service is this!!!!! I expect you to be up at 1:30am checking to see how to please your customer...............![]()
ABSOLUTELY UNEXCEPTABLE!!!
I failed huh :booo: :booo:
But its off now and in a box :awesomework:
Also--do you have any old air cleaner parts laying around? The current one aint going to work
Well robin stopped by work today to grab the res tank--and dropped off some parts.
All giddy to get the front brakes done--I ripped---that----really--heavy--tire--off
To find this :booo:
PS res will be done Monday, a new fitting is coming from Portland.
tomorrow I will have a front dirveshaft![]()
And hopefully brakes.
If your working, bring the brakes and I'll swap ya with the correct ones and give you the new shaft. What are you hours?
were you able to find the appropriate protection for your shaft?and give you the new shaft.
