The snawsage version---- something
Robin--- Is the pulleys on the p/s pumps an OEM part of some sort or is it special for those pumps?
Robin..are you ready to play bump and pass at reiter? :corn:
Not ready yet, just getting excited, now that completon is in sight. I'm sure there will also be a few bugs to work out. then I'll need a few trips to learn the new gizmos.
Do you want to bump and rub up to my sausage?
Thats not right .........:puke:
Ok robin swung by today and dropped more goodies off.
So I went and redid the high pressure hoses/T at the pumps. The fitting assembly I did for the check valves took me a # of tries to get it how I wanted--and how its retained to the bracket is pretty stout..
So I threw the res tank back on, filled the system and ran the rig for a while---with alot of smoke in the shop(exhaust burning all the crap off it)...
Ya robin--I totaly fawked up--me sorry :booo:
I fine tuned the pully alignment again (really nice now) and the damn pump slipped and bounced off the floor
So if ya have a link to the pully I will order a new one and pay for it--my fawk up....
Also get me measurments for the air cleaner box. I'll build it tomorrow
I am a while off it still robin--hang tight --I have a meeting tommorow and then one more night with the rig(short night) then yours goes out so I can spend and badly needed evening on my rig....
I'm very pleased with the way the pressure lines look. I'll swing by the Jeep dealer and pick up another pulley. Dont worry about it.
Oh I do--when I fawk up--it bugs me :mad: :mad:
But on a bright side--its the easy pully to replace,lol....
Ya the setup turned out pretty good--but I might redo it--I wanted the hose off the tee at the motor to hug the motor better........ But we will see as I was seeing double by the time I got it all done,lol...
Oh and the exhaust sounds pretty good now too :awesomework:
Then let it bug you as I go buy another one. :cool:
Got one....anything else?
Mike those are not 150 psi brass fittings are they?
What kind of pressures does hyd steering see anyways?
