ok I have an idea oin the pumps--so I will try it and see what happens...
When I put tension on the belt between the crank pulley and the first P/S pump the squeaking stopped. Take it for what it's worth.
What ratio is in the t-case now?
The problem has nothing to do with the brakes...
3.8 gears drive through the brakes easier than 4.3?
I would think it would be opposite. Someone explain
It is geared so low that I generally did all my driving in 2nd gear.
I did have the diameter of the rotors turned down, so I now have less braking surface.
From what I am seeing--the pulley needs to be encapulated more by the belt--to get full grip agains the belt--which is more important than the amount of tenion against the belt for longesvity/lasting working system..
Worse case scenario I will have to scrap the whole bracted assy and rotate the bumps and inboard the mount. That will give like 3/4 pulley coverage equally on both pumps..... I have put alot of thought into it this morning....
OK, that's just creepy! I didn't see you 'till you were on the block behind me, but I heard you headin' down the block (soundsbtw). My first thought was "I wonder if he's dog-walked it yet" :eeek:
What's the clearance on those pullies? I know they shouldn't be moving, but dang! They sure look awfully close!
Also here is the list of items I still have left--from what I can tell now
- Seats/seatbelts
- Air cleaner
- Rear bumps/lines relocated
- Rear steer safety switch
- Front drive shaft
- Nuts/bolts
What's a rear steer safety switch?
:kissmybutt: Oh that's right, he's using that POS electric doo-hicky.
Station...POS.....what do you call them? :eeek:
