ridered3
Not Rigless
Cool build thread. Can't believe you went with such a dull color for the panels after all that hard work...
d_daffron said:The rear axle and transfer case ate up a good sum of the overall budget. But the front axle is where I saved a large sum of money. I scored a +05 super duty 60 with 3.73 gears in it for $350 from LKQ and delivered to a nearby shop.
I wanted to try running a numerically lower ratio in the front than the rear to aid in steering since the SCS case didnt have a 2wd option so I kept the stock 60's front 3.73 gears to go with the 3.90's in the rear.
So for now to keep price down I decided to try these 1550 shafts ford has come out with. $308 shipped!!!! From denny's driveshafts.
no, thats not a minature pepsi bottle.![]()
After that it was pretty much just cutting and welding for a while with pretty much no pictures taken. Theres no real tech there anyway, its just cutting and welding.
Here are some pics of the pretty much completed chassis.
That's a liter colajeeptj99 said:who the hell drinks pepsi?
LightBnDr said:I love it. So how much seat time you got on most all of the original tech?
d_daffron said:Corvette internal regulated fuel filter = fail
I'm running a 300lb/hr fuel pump because I thought I'd need E85 to get thing to live at 10:1 compression and boost. So far it seems okay running 93 probably due to the efficient chambers and small bore. You cannot run one of those internal regulated filters with a high flow pump because it cannot regulate the flow. I ended up with 80+ psi fuel pressure so I didnt even get to start it before I took that stuff off and went with a regular style fuel filter and regulator.
Well dangit, Yellow was the goal unfortunately youre not the first person to say its green, one of us must be colorblind or something.muddinmetal said:Is anybody else seeing a green buggy?
This is a good point, I'm glad you brought it up. I gutted the radiator cap on the passenger side radiator then plumbed the overflow fitting from that side into a steam port. Then I left the drivers side radiator cap alone so it works like it was designed to work with a overflow tank. With that setup and the fact that I have no thermostat I was able to completely bleed the cooling system without ever cranking the engine or runnin the water pump. I dont know how it'll work after a rollover but I couldnt be happier with how easy it was to bleed thanks to the steam vents.Stuntman Autoworks said:That is awesome with the two radiators. I had originally planned to do that in my buggy for more storage area and easier packaging but I was afraid it would be a nightmare to bleed and not cool enough so I didn't try it. I had even bought the same radiators that you have but ended up selling them to some friends in their 4 cyl buggies. I may have to use that when I redesign over this winter.
