Project "Secret Squirrel"
NIce lookin REAR!
Did you just cut those brackets and reweld them or did you add some to the mix?
Jeepless said:
NIce lookin REAR!
had to both cut the bracket and then make the small flange that bolts to the housing...
YOU are the man, I think I was confused cause I swear I got all the correct parts to do a weld on type.....*smacks self in head*:D
No you did right jack--the distance from the flange to mounting surface on the toys is pretty far and I have had to do this a # of times---it just got lost in my head when you ordered the parts...:; But I am also going to run a couple small beads on the brackets once the truss is done since there will be no need to evere remove them....
Whats with all the spot welds holding the caliper brackets? I don't remember seeing the tack...tack...tack...method of GMAW in any American Welding Society literature :eeek:
Is that something new that just came out?
NotMatt said:
This is about to get really good. :redneck: :corn:
:D :D :D
I am hoping to get leveled out and some of it cut off///and get jack to get me more parts while bunks rig is here....
Love you too big guy :kiss: :kiss: :kiss: :kiss:
The rig just has to get out of the driveway--right :haha: :haha: :haha:
i wouldnt mind some of those schnazzy rear disc brakets myself. think you could get me all the specs/info on those. thanks.
p.s. GET TO WORK!
I did a rough cut on the frame to get that hunk of crap outa my way :redneck:
Here the rear axle sits roughly where it should. I am shooting for around 105" on the wheelbase..
I did a final cut on the frame about 3/4" in front of the platform that comes off the frame for the rear spring perch
And here the frame rails are capped and ready
